having problems getting carburated 350 started....
Old 11-23-2010, 10:28 AM
shawnr0517's Avatar
Default having problems getting carburated 350 started....
Hey guys just bought a car with a 350 sb has a 650 double pumper holley carb on it and I'm having troubles getting started....... any ideas??
Old 11-23-2010, 12:01 PM
What year car?
Is the fuel pump working, mechanical or electric?
Looking down the carb and pumping the throttle, do you see gas squirting?
Is your choke closed, open, part way?
Take a cap from a spray can, fill it half way with gas, pour it down the carb, and try to start it.
Then report back with results.
Oh yeah, do not try pouring gas down the carb while cranking the engine over. A backfire could end badly.
Old 11-23-2010, 01:57 PM
shawnr0517's Avatar
Ok ill c what I can do
Old 12-09-2010, 07:33 AM
XxCaMeLxxToSiSxX
Guest
Posts: n/a
you should figure out if your getting gas and spark and then move forward from there. always start simple and work from there. post ALL details that you are aware of.
example:
it's getting spark and it's getting gas to the carb but isn't starting. It back fires or sputters as it's cranking.
All information is of extreme use when trying to diagnose a problem.
cricket5150
82-92 V8 Tech
09-07-2009 10:01 PM
sledhed32
11-18-2008 07:41 PM
ves800ultra
04-01-2008 12:57 AM
Ellas87Z28350V8
82-92 V8 Tech
09-20-2007 09:59 AM
azzkikn z28
08-05-2006 03:03 AM
Quick Reply: having problems getting carburated 350 started....
