small block numbers-HELP!!
Old 10-25-2010, 05:44 PM
coupeman's Avatar
Default small block numbers-HELP!!
I have a 81 Camaro with a non original engine in it. I cant seem to find out what the engine and heads are so here are all the numbers, hope someone can help. Block casting number is 3970010-alsoA 20 5, these are are on the back of the engine. On the front pad just above the waterpump , under the alt are these numbers, C5B127127 V0127T. Head casting number is 378450 ,also on the heads is GN9T and E 10 79. Cant seem to find out what this is so if anyone can help I would appreciate it. THANKS!!
Old 10-25-2010, 08:55 PM
The "3970010" is a pretty common block, used in 1969 for the 302, and from 1969-80 for the 350.
"A 20 5" is the date code. A=January, 20=day of month, and 5 would have to be 1975 (the only year between 69-80 that ends with a 5).
C5B127127: C= that I'm not so sure about because a "1" instead of C= Chevy (maybe there's a difference because of what it came out of...read on), 5=1975, B= Baltimore, Maryland VIN assembly plant (not engine assembly plant), and the rest is the partial VIN.
V0127T: V= Flint engine Plant, 01= assembly month (January), 27= day of the month, T= truck motor division
The "450" heads were used on 267 and 305 engines. "E 10 79" date code is May 10, 1979.
So...you have a 1975 350 truck engine with 1979 267/305 heads.
Oh yeah, and here's a good link to research from: http://www.chevy-camaro.com/chevy-ca...oding-help.asp
Old 10-27-2010, 07:40 PM
bowtieguy's Avatar
July 2009 ROTM
You can also look up the numbers at www.mortec.com
Old 02-11-2016, 10:02 PM
I have a engine that has 3970010. On front of engine it has Eo329ckl 13j250675. Thank you.
Old 02-12-2016, 05:54 AM
Everett#2390's Avatar
0329 = Mar 29, CKL = 1973 350 California (emissions)
13J = Chev, '73, Janesville WI, vehicle assembly plant.
Thank you '69, for the link.
Old 02-12-2016, 10:26 AM
Default Motor Vin
I have a 350 with 3970010 on back of engine. On front it has V1122tbd and c9f369258. Thank you very mutch.
Old 02-13-2016, 01:33 PM
C9 = C-series model truck, 1979
V = Assembly plant Flint, MI
1122 = Nov 22
TBD = 1979 350 4-bbl, 165HP, Federal emissions
You're velcome
Old 03-12-2017, 03:32 PM
Joey Hockett's Avatar
Default i have 2 engine blocks to decode help plz
1122 = Nov 22
You're velcome
Can anyone help me decode 2 engine blocks
First one is 3914660. TO 626 HI
2nd is 3858180. TI 008 HCH
Old 05-11-2023, 09:05 PM
Augster's Avatar
Default Matching numbers
Is this a matching numbers car TIA
Old 05-11-2023, 09:42 PM
You should start a new thread,this one is over 10 years old.
snopro_16
67-69 V8 Tech
14
08-23-2022 04:08 PM
decaen
02-16-2012 01:08 AM
gadmhahn
10-09-2009 09:20 PM
acarius
04-07-2009 05:53 PM
Carinhas
67-69 V8 Tech
13
08-23-2007 05:02 PM
Quick Reply: small block numbers-HELP!!
