Engine code
Old 02-03-2008, 05:02 PM
Painless's Avatar
Default Engine code
Hello!
I am new here in the forum and my english is not so good (I come from Germany), but I hope you can help me.
So now to my question, I have bought me a Camaro where but now another engine is now built, I wanted to know what kind of an engine is, unfortunately, I find no data on the internet to the motor.
The engine code is 1M12037VP
With friendly sincerely,[/align]
Old 02-03-2008, 05:11 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: Engine code
it doesnt matter where your from,everybody sounds the same on here.go to www.mortec.com ,you can find all the numbers there
Old 02-03-2008, 05:49 PM
Painless's Avatar
I think no because unfortunately the number. It is a normal GM 4 Bolt engine 550-600 hp with compressor and other Tunig share still
Old 02-03-2008, 05:51 PM
Painless's Avatar
I think no because unfortunately the number. There should normally be a GM 4 Bolt engine with 550-600 hp compressor and other Tunig share still
Old 02-03-2008, 06:19 PM
firebird69racer's Avatar
ORIGINAL: bowtieguy
Mortec is just for casting numbers
Here are some others that have more info about block number stampings, cowl tag, and vin. #'s
http://www.nastyz28.com/sbchevy/sblock.php
http://www.camaros.org/index.shtml
http://www.chevy-camaro.com/
Old 02-03-2008, 09:29 PM
kyphur's Avatar
What year is this car and engine? Where are you getting the engine code from? Is right in front of the passenger side (american passenger side) valve cover? If you can get the casting number off the back of the engine that could give us a lot more information. It sounds like you're giving us the engine ID code and I couldn't find a VP suffix.
Old 02-04-2008, 05:10 AM
Painless's Avatar
The car is Built on 79 engine because I have no info
I know only that the engine goodwrench 4Bolt a GM engine should be.
Because code I read here:
http://img253.imageshack.us/img253/5...2513151le8.jpg
'Maro!
03-16-2014 03:11 PM
pajen
07-31-2012 07:12 PM
adam68
04-12-2012 07:44 PM
Tim L
02-07-2008 10:06 AM
Tim L
70-81 V8 Tech
01-31-2008 09:33 PM
Quick Reply: Engine code
