Could this be a problem? (image included)
I picked up this motor - it has very little run time (maybe a 100 miles)...
350, bored 30 over, new pistons --
Take a look at the image at the link below. I don't know much about what is reasonable with engine rebuilds, etc. So --
I am asking about those straight line scoring marks produced by the piston skirts. They are on every cylinder - about the same -- They are very minimal (you can't 'feel' them).. I can turn the crank, no problem.
However, is that normal? Is that going to cause a problem a bit later? Could this cause the engine to run hot? Nothing to be concerned about?
I plan on installing this motor ASAP and running it, UNLESS I get feedback that this is a NO GO with those pistons and their 'fit' in the cylinder.
https://www.evernote.com/shard/s15/s...0a62e3a2f711b8
wow, pictures make it look bad, first response was woh theres something wrong. but then i read you cant feel them. so your buying this engine? i would keep looking, but just me.
Since you bought it, hopefully, the camshaft was broken in good
Use a good 10W30 oil as the piston may not have been very clean when installed
Or there was no oil on the piston/rings at install.
Generally, the piston is submerged in oil before installing for assembly lube and cylinder is rubbed with oil.
Was the engine broken in?
Was the break-in oil changed?
Why the sale after 100 miles?
CamyGal
09-10-2009 08:05 AM
libertyforall1776
11-26-2008 05:23 PM
