Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
The Fuel System
Old 02-25-2015, 11:37 PM
paris0145's Avatar
Default The Fuel System
How do we know a bad fuel pump? This is very important to car engines to start, But how do we spot a bad fuel pump to a good one.
Old 02-26-2015, 01:02 AM
Check fuel pressure with engine under fuill load.
Old 02-26-2015, 07:54 PM
paris0145's Avatar
yup, I and uncle already did that procedure... i know that all fuel pumps were always mechanical. This means that they operate through a system that runs off of the rotation of the engine itself. i'm not that knowledgeable in mechanical features of these products but its really frustrating now. should we return the product to the online auto partswarehouse store where we bought it?
Old 02-26-2015, 07:55 PM
paris0145's Avatar
was also reading some article like this one 5 Common Symptoms of a Malfunctioning Fuel Pump | eBay for any help that we can get but unfortunately no luck
Old 02-27-2015, 12:52 AM
Most mechanical fuel pups work off a special lobe on the camshaft and use a short push rod to work the lever on the pump. Mechanical pumps are usually intended for feeding carburetors and have a working pressure of under 10 PSI. What problems are you having?
Old 02-27-2015, 07:00 AM
With the engine off, look down the carburetor and pump the throttle by hand. If you see gas squirting, that means your fuel pump is working and your problem is elsewhere.
If you get nothing, then it could be fuel pump, could be fuel supply blockage from the tank, could be the carburetor float being stuck.
Yes, it would be helpful to know exactly what you have and what it's doing.
Old 02-27-2015, 07:53 PM
paris0145's Avatar
I'm already experiencing some form of a sputtering, stuttering, stammering during start. I guess I really have to consult expert mechanics about this guys. I'm also calling auto parts warehouse for the defective product I bought from them. I will be asking for a replacement or total refund.
Old 02-28-2015, 01:53 PM
Not much to go on. lol
H2C
11-10-2010 11:41 AM
vogel822
05-27-2010 02:06 PM
90iroc-z28
04-27-2009 01:36 PM
Liferollson9987
82-92 V8 Tech
09-29-2007 03:21 AM
xhardkn0ckz
05-01-2007 11:42 AM
Quick Reply: The Fuel System
