Wiring Diagram 95 v6? - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 04-22-2008, 08:30 PM
Default Wiring Diagram 95 v6?
hey, i just got the car, it camewith an after market stereo, and a kit tohold it in the stereo slot, and something is wrong with the wiring(im guessing), and when they installed it they just cut the wires and tied them together and taped them, but maybe its supposed to be like this i really idk, but the wires that say "POWER" and "CAR BATTERY" coming from the radio are both tied onto the same single wire coming from the car. and whenever the car is off, the radio turns off(backlighting, sounds etc)
but there is still a clock on it(supposed to be on while car is off)and the radio drains the battery when the car and radio are off(but the clock is still on) so can you tell me if the "power" and "Car battery" are hooked up correctly? and if not, could you give me a diagram or tell me what colors are what coming from the car(front speaks, ground, power,battery etc), the ones from the stereo are already labeld, thanks, sorry for the long post
Old 04-22-2008, 09:11 PM
DeZ DeZ is offline
Default RE: Wiring Diagram 95 v6?
from installdr,
dash color - cd player color
A Left Front Spkr (-) Light Gray - White w/ Black Stripe
B Left Front Spkr (+) Tan - White
C Right Front Spkr (-) Light Green - Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green - Gray
E Ground Wire Black - Black
F Not Used
G Headlight Dimmer Wire Gray - Orange (if available)
H Power Antenna Turn On Pink - (if available) Blue
I +12 Volt Ignition Wire Yellow - Red
J +12 Volt Battery Wire Orange - Yellow
K Right Rear Spkr (-) Light Blue - Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue - Purple
M Left Rear Spkr (-) Yellow - Green w/ Black Stripe
N Left Rear Spkr (+) Brown - Green
onto your problem i had the same problem with my eclipse, the female apdt was missing so there was no way for me to tell if i had hooked up correctly or not.
but the simple solution is run your ( red,yellow wire them together ) along with your ground wire to the battery terminals. 18 gauge wire needed. the only ***** about this is you have to manually turn off and on and most likely lose all of your key acc features until you have key on.
Old 07-01-2008, 07:05 AM
i doubt its your stereo first diconnect deck and see if the battery still dies
Reply
Thread Thread Starter Forum Replies Last Post
Wiring Diagram 2Z's 93-02 General 6 06-13-2012 08:13 AM
i need a wiring diagram for 3.8 Katzen 93-02 V6 Tech 0 05-01-2011 04:11 PM
wiring diagram camaro89rs Audio/Visual Electronics 2 10-08-2007 07:11 AM
wiring diagram z28scorpio 82-92 General 2 04-11-2007 06:27 PM
wiring diagram bowtieguy General Tech 3 02-19-2006 09:16 PM
Tags
95, battery, camaro, camaros, cd, chevy, deck, diagram, electrical, firebird, pictures, rewire, schematics, v6, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
