Replacing Monsoon System Complete?????
Old 10-23-2008, 07:38 PM
sschic's Avatar
Default Replacing Monsoon System Complete?????
Ok, my 1999 Monsoon system has seen better days and I'm sick of listening through 1 speaker and skipping CDs. I'm planning on replacing at least the head unit and all 6 speakers, but had some questions on the amp and wiring.
I can either try to find appropriate ohm speakers to work with the stock amps, find a set of small woofers for the rear seat speakers or completely overhaul the system.
I would rather avoid replacing everything and buying new amps to boot, but don't think it will be an easy task finding a set of 2 ohm speakers to work with an aftermarket deck.
I'm looking for options. I can't run all 6 speakers off an aftermarket deck, so I'll have to run an amp. I'm not looking to win any competitions, don't want to run a subwoofer, just a simple system w/ a new deck and speakers. What do you guys think is the best, cheapest way to do this.
Old 10-23-2008, 11:46 PM
sschic's Avatar
Default RE: Replacing Monsoon System Complete?????
Ok, found this for the front speakers.
http://www.epinions.com/review/Infin...t_443712769668
The front speakers are 6.5" and split the tweeter and woofer.
Anyone see anything for the other 4 speakers.
Old 11-02-2008, 01:14 AM
Skippysnax's Avatar
i have a better idea, screw the amp idea, and just hook up 4 speakers. If thats not enough then just run a 4 channel to em. cheap and simple, dont make it hard on urself
Old 11-02-2008, 02:10 AM
RFxCamaro's Avatar
yea skippy is right o and those back speakers are a peice of bull comeplely useless
Old 12-04-2008, 09:19 AM
jjbova's Avatar
I was under the impression the front and sail panel speakers were 6.75", are you saying the 6.5's would fit? Cause that would help out with the searching over all. Also, do we have any one who has either a schematic of the stereo system, or pictures of where everything is at (Amp, speakers, wiring harness's, etc.). I am still trying to find the dam Monsoon amp, lol.
Old 12-05-2008, 10:59 PM
M.$tErNeR's Avatar
its funny b/c i was just looking at this amp the other week and thought for someone who didnt know exactly where this is,this could be pretty confusing and annoying.lol but its not to bad..remove your passengar side plastic panels in the back (under the hatch where the one small speaker is at,takes like 3 little plastic pins that you have to turn from locked to unlock).then u have to remove the spare wheel(good time to check if theirs actually air in it in case u mite actually need it one day.lol).after thats off you'll see the amp back in there,it looks kind of triangle shaped with the mounting bracketbut heres a pic off ebay so u know what it looks( likehttp://cgi.ebay.com/ebaymotors/98-02-Camaro-Firebird-monsoon-amplifier-OEM-factory-132_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116Q QitemZ310100692398QQptZCarQ5fAudioQ5fVideo)
Old 12-06-2008, 08:10 PM
02StanGT's Avatar
I just saw it for myself today. Still not sure what kind of system I have... When I bought the car, it had a tape deck and six speakers. Swapped out the tape deck for a factory CD player, and found out today there is an amp in the trunk mounted near the spare tire.
Old 12-09-2008, 11:48 AM
jjbova's Avatar
That does help. I don't know that I will do anything wiht it. but this way if I ever wanted to tap into it or remove it I know where. I used to have a car that had it under the passenger seat... very handy.
So that amp only powers the frond door and sail panel speakers, correct? So why did they run it to the back first? Seems kinda odd not to find somewhere more efficient to put it.
hackson
04-17-2020 06:19 PM
bkluffman
01-23-2013 09:51 PM
auto
04-17-2012 05:26 PM
bob97z28
02-18-2012 08:08 AM
GreatWhite00
03-03-2007 03:56 AM
Quick Reply: Replacing Monsoon System Complete?????
