Factory radio replacement 00 Camaro
Old 05-25-2010, 04:18 PM
SS_2000's Avatar
Default Factory radio replacement 00 Camaro
I have a 00 Camaro ss with the monsoon sound system with the 12 disc changer in the back and want to know if i replace the factory radio unit with a better aftermarket one will i still be able to use my much loved steering wheel controls and 12 disc changer???? Thanx
Old 05-27-2010, 04:52 PM
libertyforall1776's Avatar
Do you really have to post the same thing multiple times in different categories?
Repost:
There are kits out there to keep that functionality, but I have never replaced the monsoon system.
If you are just looking for iPod/iPhone/iPad & AUX inputs, the best option is USA-Spec, which plugs into the CD Changer port, also has a adapter cable which should keep the CD Changer functionality too. I have this for my RS & SS -- works for me.
http://www.usaspec.com/product.php?ProductID=25
Old 05-27-2010, 06:15 PM
SS_2000's Avatar
Cool thanks. Well i posted in the audio section and saw theres not much traffic through there so i reposted it. What my concern was i was thinking of replacing the head unit to a better one, I had a 95 z28 with the premium bose and i replaced the head unit because the cd player stopped reading cd's and the new deck made a world of a difference with the facorty set up, thinking the monsoon may be the same way. But i do not want to loose those two functions on my SS. So yeah.
Old 06-15-2010, 11:48 PM
greenarrow's Avatar
September 2009 ROTM
There are several aftermarket companies that make addional harnesses so you can keep your steering wheel controls. I have a kenwood DVD in my jeep and I found a aftermarket adapter that I only had to tap into one wire from the jeep harness to make it work.
hooknladder
03-26-2011 11:44 PM
SS_2000
LS Series Tech
06-19-2010 03:04 PM
auto
10-19-2009 11:40 AM
danimaldds
06-12-2008 11:59 PM
ravenkil
06-24-2007 02:53 AM
Quick Reply: Factory radio replacement 00 Camaro
