will these fit?
Old Apr 9, 2012 | 07:10 PM
Ryansblack95z28's Avatar
Default will these fit?
hey guys i just got my first camaro saturday so im still new to the car stuff, im use to buying truck parts, anyways im looking at getting a set of oe c5 wheels with 17x9.5 fronts with 275-40-17 and 17x11 rear with 315-35-17 the car is stock height. will those fit?
Old Apr 9, 2012 | 08:08 PM
whats the offset? did the c5 come with 11in rear rims? http://www.camaroz28.com/forums/whee...2/#post3422887
Old Apr 9, 2012 | 08:26 PM
Failed Devices's Avatar
They could be from OEwheels.com, and the offset has to be below 56mm for the rear. You will probably need to do the BFH mod to cram the 11" rim and 315 tire. You could play it a bit safer and run a 305, but the BFH may still be required.
Old Apr 10, 2012 | 06:21 PM
yah there off of oewheels, the rear offset is 50 and front 56
Old Apr 10, 2012 | 06:22 PM
BFH? bigger feeing hammer???
Old Apr 10, 2012 | 07:02 PM
Are you sure its an 11" wide rim? I thought OE wheels only went up to a 10.50. Also I think you have your offsets mixed up, the larger offset is usually the rear one. Yes BFH means big hammer, and that would be needed for an 11" rim with a 56mm offset, you also might have to roll the fenders and get an adjustable panhard bar
Old Apr 10, 2012 | 10:36 PM
50 will work, i think mine are 52. i have 17x11 inch wheels with 315s on the back of mine. i did do a little wacking with a hammer and rolled the wheel wells just to be safe.
Old Apr 12, 2012 | 09:23 AM
ok thanx guys, i checked the site again and the wheel offsets are what i said i dont know why the front is more but thats what they are saying. thanx again
