tail lights
Old 03-13-2014, 10:03 PM
camaroteen82's Avatar
Default tail lights
so I'm having an issue with my tail lights. when the lights are on their the same brightness but when you press on the brakes the driver side gets brighter but the passenger side dims. I'm not exactly sure whats going on with them.
Old 03-13-2014, 11:04 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
You have the bulb in backwards, take the one that dims and rotate it 180* and put it back in the socket.
Old 03-18-2014, 11:49 AM
v64thgen's Avatar
hahaha, i've done that before
Old 03-18-2014, 02:48 PM
is that the flat style bulb or the round style bulb? because it has the round style bulb and if I switch it around I have no tail light on the passenger side.
Old 03-18-2014, 03:02 PM
Sounds like you have a bad ground associated with the passenger side light wiring.
Old 03-18-2014, 03:28 PM
I've cleaned the only ground I've found and that was in the hatch.
did the 98-02 camaros come with the flat style bulbs? would the tail light harness from one plug into the one on my 97?
Old 10-09-2015, 03:06 PM
Karate's Avatar
ya, the later gen 4 had the round style bulbs where you could put them in either way and they would work. Find the ground ring lug for the rear wiring harness and take it off and clean any rust under it.
98Z28ImportSlayer
03-16-2012 09:07 AM
CamaroKidd
05-11-2011 11:25 AM
RS camaro
09-08-2010 01:00 PM
vXIcetreyXv
10-23-2009 07:25 PM
bodykits
07-01-2009 09:52 PM
Quick Reply: tail lights
