Fog lamp questions on 97 RS
there is a aftermarket kit like $32.50 that will fit right in there i have a set i never used couse iwent with the diffrent front end ,has the wireing harness an everthing you need fuse, an look so much like the stock set up wich i did not like couse they fade ,a stock set up may cost 3 times that used,type in 1997 camaro fog lights on ebay should be right in the first few items ,they also have other choises but if you want a light that looks as close as stock or better its the way, there 5 inchs long x 1.75 i think the stock ones are 6 inch x 1.75,they also have led types that alot of guys are going led clears,those you could hook right up to the headlights or run your own switch or tap into the one there i think is the way its made the kit that is
I'm reviving this thread because I have now gotten around to figuring out the fog lights again. Does nyone know if all Camaros in 97 would use the same harness? I can't for the life of me think they would put in different harnesses per option. So where the fog light relay is supposed to be there are no plug ins. but I popped off the fuse panel and it's only wires running to each option. without unwrapping the bundle of wires I figured I would ask and see if anyone has done that before?
libertyforall1776
04-23-2007 04:15 PM
