what is the easiest way to remove a starter? - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 05-19-2007, 07:54 AM
Default what is the easiest way to remove a starter?
my dad has a 94 3.4 and it has had recent starting problems. at first it would hesitate to start, taking a few tries to get it to. now when we try to start it, it just makes a clicking noise. i had the alternater tested and there is a new battery in there so that led me to the starter which is a pain in the *** to get out. once i have all the bolts off, where should i pull it out of the car because it looks to me like it will be tight getting out due to mainly the exaust that is getting in the way
thanks for the help
Old 05-19-2007, 12:11 PM
May 2007 ROTM
Default RE: what is the easiest way to remove a starter?
have you checked the battery cables, I had the same problem with a 68...replaced the battery, Starter, Volt regulator....only to find out that a 6 month old pos cable.
Old 05-19-2007, 12:29 PM
yea there is nothing wrong with those at least from what i can see... what could i check for on those to see if they were bad?
Old 05-19-2007, 12:47 PM
There is no easy way, but see your other post.
Old 05-19-2007, 04:28 PM
yes as pete stated and as i know from personal experience on my 94, there is no easy way. The exhaust must be dropped no question. I would suggest taking this to a mechanic if you do not have the proper tools to drop the exhaust, also if you do not have the exhaust properly tighten up and placed/aligned you will hear a constant vibration/ rattle that really plagues the ears during low rpms esp take off.
Reply
Thread Thread Starter Forum Replies Last Post
How to remove cable from back of starter switch jlbonnie2000 93-02 V6 Tech 3 01-13-2014 06:31 PM
what are the easiest bolt ons xXChipXx LT1/LT4 Tech 2 12-28-2010 10:42 AM
Easiest way to increase hp Bwalker 70-81 V8 Tech 5 09-17-2009 09:24 PM
Which cold air intake is the easiest to remove and clean.Thanks 1995CamaroZ28 93-02 General 11 04-26-2008 12:09 AM
easiest way to do burn outs 408camaro 93-02 V6 Tech 7 06-04-2007 04:25 PM
Tags
2000, 31l, 34, 34l, 68, 94, 95, camaro, drop, easiest, easy, exhaust, remove, starter, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
