Fuel Pump
RE: Fuel Pump
It's a little difficult. The pump is located inside the tank. Some people recommend you drop the tank, others say it's possible to be done with a partial removal. I have no idea how much it would cost to have someone do it for you. Call around and have some estimates made.
RE: Fuel Pump
They are inside the tank and yes they are a ***** to do. You normally have to drain all the gas if not you have a reall heavy tank of gas to set on the ground. If i were you i would take it in. It will be a little expensive but its completely worth the money rather than the hastle.
BTW 50th post....
BTW 50th post....
johnson3034
05-25-2007 09:35 PM
