water pump direction 1995 v6 camaro
If the pump is driven by the back of the belt it is a reverse rotation pump, CCW rotation. If it is driven by the front of the belt it rotates CW. Being that you are changing pulleys you will have to figure out how the pump is going to be driven. If using V belts, the back of the belt is not going to be able to drive the pump.
