spark plugs and wires
MSD 8.5MM wires, Denso plugs on my 3.8L, check out - Tom Henry RS V6 Camaro Project
for info on why the Desno's, and unless you've done a bunch of mods, you don't need to change the heat range from what's recommended stock.
8mm will be fine for your car, i got mine from summit. the plug tool dosent really help, just make sure you use quality components, heat shields and wire holders this is not something you want to do often. youll be running wires through some very hot spots..
I used MSD 8mm and Denso Plugs, good comment above on the heat shields the ones near the headers get HOT, keep the metal shields on them if you still have them.
Good luck with the rear passenger one, I still have not go that one out.
QUICKB4C
06-15-2009 11:52 AM
