Reset ABS/Brake codes? Help!
Old 06-08-2007, 11:54 AM
libertyforall1776's Avatar
Default Reset ABS/Brake codes? Help!
Anyone know how to reset ABS/Brake codes w/out a ABS/Brake scanner?
Thanks in advance.
Old 06-08-2007, 12:48 PM
Default RE: Reset ABS/Brake codes? Help!
Need an ABS capable scan tool. The codes won't reset if the trouble is still there.
Old 06-08-2007, 03:32 PM
bluovlh8er's Avatar
can you unplug the battery for 6 hours?
Old 06-08-2007, 03:37 PM
Will that work, or are you assuming it will? Speaking from experience?
Old 06-08-2007, 04:33 PM
You can unplug the battery for 6 days, but if you haven't fixed the ABS problem, the light will come back shortly after the vehicle starts to move.
Old 06-08-2007, 04:49 PM
Umm, 6 days or 6 hours??!
Old 06-08-2007, 05:59 PM
V1cinity's Avatar
What Pete meant is that it doesnt matter how long you unplug the battery, the problem needs to be FIXED or the light and codes are going to keep coming up.
Old 06-08-2007, 09:28 PM
LOL, ok ;-)
Well, it seems the system needed time to recalibrate itself or something, since the lights finally went out w/out disconnecting the battery! They were lit solid until I replaced the ABS Motor Pack (well and for a day after that)... and yes, the shop verified all three ABS wheel sensors read the same speed, so sensors are good... Hopefully the light will stay off -- time will tell!
Woot!
HeavyChevy77
12-20-2012 11:23 AM
skylinrcr01
11-04-2008 06:43 PM
maudyZ28
08-29-2007 12:40 PM
ashmason
11-16-2006 03:28 PM
Ransak
11-12-2006 12:02 AM
Quick Reply: Reset ABS/Brake codes? Help!
