3.4L vs 3.8L
Old 06-24-2006, 05:09 AM
heavy_foot's Avatar
Default 3.4L vs 3.8L
How much fatser is a 3.4L Camaro vs a 3.8L?
Thanks in advance
Old 06-24-2006, 04:52 PM
94Z28SHAKER's Avatar
Default RE: 3.4L vs 3.8L
its not, the 3.8's walk all over them.
Old 06-27-2006, 04:14 AM
loochy88's Avatar
3.4----------3.8
160hp-------200hp
mid 15's-----low 16's
Old 10-06-2006, 03:49 PM
airchevy02's Avatar
how can a 3.4 have less horsepower and run a faster quarter mile? Same setup besides the motor right?
Old 10-06-2006, 11:25 PM
I would think that the more powerful engine would turn the better times, not the other way around.
Old 10-09-2006, 01:06 AM
Raidenvaga's Avatar
3.4 weight , weight of 5.7 , then weight of an 3.8 is weird.. 3.8 are heavy... they are using cast iron heads right ????
Old 10-09-2006, 08:31 AM
AlfredB18's Avatar
I believe the 3.8L does use aluminum heads, but it is pretty piggish.
I swore it was at least as heavy as an LT1, but maybe it is in comparison to an LS1.
But, a 3.4 is all iron, so I can't see those given numbers being right, either.
Old 10-09-2006, 06:46 PM
Raidenvaga's Avatar
I know what you mean.. I seen the 3.4 for 3250 , 5.7 for 3400, & 3.8 3400-3500... Something isn't right. If it is then weight deduction for 3.4 will be an very good idea
Old 10-09-2006, 11:10 PM
Bubonic's Avatar
I havent seen anything above 3400 for the 3.8s. These cars are just so freakin heavy.
Old 10-10-2006, 04:53 AM
Matt99camaro's Avatar
I've never met a 3.4 that could beat my 3.8. My ex had a 3.4 Camaro. We raced several times and I beat it every time. I let her drive mine and I drove hers since I'm a better driver, it was closer but she still took me in my Camaro.
