flouded engine
Try to dry out all ignition parts first. There is a special spray available at your local parts store. Hopefully, the engine did not swallow much water, otherwise hydrolock and broken parts is a possibility. Next time drive around deep water.
If you think you may have sucked up some water, it would be smart to remove the spark plugs, and crank the engine over to blow it clean. Then before starting the engine again, remove the intake hose from the T.B. just in case your air cleaner is water soaked. Check to see if it is soaked.
martynlutherking
05-25-2010 11:12 PM
