Radiator Flush Citric Acid Question
Old 08-03-2007, 12:01 AM
94CamaroSFI's Avatar
Default Radiator Flush Citric Acid Question
I just check my radiator and ive got some sludge in the core, The other day i was skiming through a site somewhere and it mentioned using Food Grade citric acid to clean the core, Can anyone give me the directions into doing this?
Old 08-03-2007, 11:50 AM
libertyforall1776's Avatar
Default RE: Radiator Flush Citric Acid Question
Prestone super flush is basically the same thing -- look at the ingredients...
Old 08-03-2007, 12:06 PM
I Found this over at 60DegreeV6.com Forums
materials needed:
10-15 gallons distilled water
3-5 lbs citric acid, use food grade citric acid.
Steps:
Engine cold
1. Open heater control valve to max temp, remove lower radiator hose and heater core line, drain old coolant into container and discard.
2. Reinstall hoses and refill with distilled water. (if your engine has a specific air bleed requirement perform it per the manufacturer)
3. Operate the engine for 3-5 minutes at high idle.
4. Let cool at least 10 minutes then drain coolant. Do no be impatient, if you dump the coolant too soon you can warp components due to heat soak effects.
5.Using a plastic container mix citric acid with water to form a thick soup.
Pour the "soup" into the radiator filler. On a badly scaled system go heavier on the citric acid.
6. Refill the unit with distilled water. Bleed air as before, operate engine to purge air properly (again per mfgs directions) then let the engine fast idle for 45-90 minutes. If you have a tachometer 1500 RPM is OK. Keep an eye on the temp gauge to make sure that your unit does not over heat during this procedure. On a badly scaled 4 cylinder engine I've found the process takes a little over an 45 minutes. The indicator I used was the temperature gauge falling (engine getting cooler) as the radiator efficiency increased.
7. Drain, refill with distilled water, purge air and operate the system as described under items 2, 3 and 4 at least three times minimum. Unless you have very soft water resist the temptation to use a garden hose for this step.
8. Refill with the correct mixture of your anti-freeze of choice making sure to purge air as required. Operate the engine for a few minutes to check for leaks.
9. Take a last look to make sure that lines and connections are tight and all tools accounted for before you close the hood.
In my opinion if you are converting from Dex-cool to another type of anti-freeze this technique removes desposits very well and presents the best possible set of conditions for a successful switch over.
This technique has worked well for me, it is up to you to determine if the procedure can be safely carried out on your vehicles' cooling system. I cannot be held responsible if your system develops leaks. I have found that some pinholes developed on the radiator in one of my vehicles that the earlier scale masked.
Good Luck
Andromeda
on a side note i dont think i will do this because i dont really feel like letting the car idle for 45-90 mins...
Raven93
04-19-2014 09:51 PM
Jeepin
11-16-2011 02:26 PM
BoricuaHec01
LS Series Tech
03-15-2011 08:57 AM
triumph601
03-31-2008 10:04 PM
ohiocopper12
02-06-2007 01:53 PM
Quick Reply: Radiator Flush Citric Acid Question
