No transmission dipstick on camaro?
I'm probably just overlooking it, please don't get mad at me
Im trying to figure out where's my transmission dipstick to check the levels on it. I'm a newbie.(2000 chevy camaro v6)
manual trans does not have a dipstick. to check gear oil you will need to get it up in the air, level and pull the plug off the side of the trans. stick finger in and see if the oil level is even with the hole.
usually i have found that oil comes out, lol, guess i dont get the car level. its supposed to be level with the bottom edge of the hole. im sure as whoever filled it it got a tad over
Since you are new to the hobby it would help if you would do some research on you car. Like get something like a "Chiltons"or a owners manual for your car. Sorry if I may sound rude .but I`m trying to help you .in many different ways.A including there are many things you can do yourself.Instead of having a shop do it.(And shops aren`t cheap) From most of what I gather from visiting this site most of do.Good luck to you.
