Just did the valve cover gasket and...
first of all i'd like to say hi.
and on to the point, as it say i just did valve cover gasket on my 95 v6 3.4
and well now it has a heavy miss and no power i floor it and like my old car no where fast.I've checked ever wire i can see or remember and made sure its all tight did how ever wind up with a bolt left over keep in mind the owner before me lost a lot of the screws ext any good idea's i'm out
Did you have to remove the plug wires from the coil paks while you were working on it? If so, are you 100% sure you put them back on in the right place? Any chance you could have broken one at the end of the wire by pulling on it? But if you have checked all the obvious, as craby says, scan it.
voxeltoxin
12-14-2014 02:24 PM
