Ignition switch?
Old 09-22-2007, 08:35 AM
rayden7157's Avatar
Default Ignition switch?
Well I seem to be having a problem and not sure if its the switch or something else.When i was driving home the battery voltage was going from 13 to about 5 volts.I got home and when i shut the car off it wont doe nothing now you turn the key to try to start and it does nothing and nothing seems to work that has to do with the ignition gages aren't working and cooling fan dont come on and motor wont turn over.Any ideas on what it is and how to fix is appreciated. Thanks
Old 09-22-2007, 10:23 AM
Default RE: Ignition switch?
IMO the battery died, probably because the alternator died, or you got some loose cables. Get the battery tested. if OK get the alternator tested.
Old 09-22-2007, 11:06 AM
rayden7157's Avatar
The only thing is that radio and headlights still work fine just when you turn on the ignition key nothing happens the running lights don't come either when you turn the ignition key on and they use to. Also I did smell like something burned inside but i'll check the battery and alternator just to be sure .Thanks
Old 09-24-2007, 04:39 AM
Cosentino's Avatar
Did it drop from 13 to 5 nearly instantly or did it take a short period of time?
If instantly, I'd say a lose/bad battery cable or (less likely) ignition switch wire
If it slowly drained down over like 30 minutes then I'd say drained (probably now bad) battery caused by a bad alternator.
Easiest way to narrow it down between bat/alt or bad wire/cable would be to have someone try and jumpstart you. If you can start the car and have no problem as long as you're hooked up to their car then I'd say it's not a wiring issue. If you're still having the problems then your wiring is bad.
Old 09-26-2007, 12:10 AM
libertyforall1776's Avatar
Could be your battery is dying, bad alternator, bad wiring, bad starter/solenoid, bad ignition switch.
You can test the power going to the starter at the starter to see if the juice is making it. I believe Autozone will test your starter (not sure if it is free).
Delray Gugle
04-07-2014 07:04 PM
tampatony
02-20-2014 01:59 PM
evilmnky45
07-31-2011 05:24 PM
qqqa
07-28-2008 12:27 PM
w0211644
03-14-2007 01:12 AM
Quick Reply: Ignition switch?
