how to replace this hose???????
Old 07-03-2014, 11:37 AM
subysti's Avatar
Default how to replace this hose???????
OK this is a 96 convertible with the 3800 V6. Leaking coolant everywhere and making a noise. I replaced pump and then found hose tucked above and behind pump that was cause of the leak. How the heck to I replace this stupid thing???? its an L shaped hose about 2" long.
pics below
imgur: the simple image sharer
Old 07-03-2014, 03:28 PM
fbodyrs96's Avatar
get the new metals one, no more problems DORMAN Part # 47065HP
the 96 only has the upper one that you have leaking, to change drain radiator, remove alt, then remove the alt/tension assembly. Be careful since its already broken, its going to fall apart when you remove the tension. Make sure you get ever thing out of that lower intake port.
xcorat
07-31-2014 11:42 AM
94ChevyCamaroV6
08-14-2012 01:18 AM
mab6680
12-23-2010 08:01 PM
black95z28
04-19-2010 11:28 PM
TomS68
04-04-2008 09:52 AM
Quick Reply: how to replace this hose???????
