Engine is actin like a miss fire.. rough idle. Neep help! - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 07-06-2010, 09:04 PM
Exclamation Engine is actin like a miss fire.. rough idle. Neep help!
98 Camaro v6, 141K. Car is pretty well taken care of and I have done lots of perventive/maintenance on this car. Anyways, my car is having a miss fire like a rough idle and when im accelerating it acts like it has no power and just miss fires. Going 70 on the highway it does just fine, but as soon as you give it some gas to pass a car, it starts miss firing and even to the point it jerks the car a slight bit when the engine does this. Me and my dad thought it might be the spark plug wires so we changed them. Did really no help.
When this rough idle at times/missing on acceleration, I have noticed that this mostly happens after I drive it in the rain through a hard storm. It has been this about 5 times before but usually it goes away after 1-3 days. I have been putting lucus fuel addative in it before and this seemed to help.. not this time.
Don't really know what it could be..???
Old 07-06-2010, 10:06 PM
libertyforall1776's Avatar
Change the plugs at the same time as wires? If not, try that next. Be sure you use dielectric grease.
Get your injectors NOID tested. Any SES codes?
Old 07-06-2010, 10:18 PM
Could also be the coil packs. But as Libertyforall says, need to check to see if any codes before just throwing parts at it.
Old 07-08-2010, 04:11 PM
The service engine light has been on and off for the past year... car ran fine so I did really nothing about it. Sence I changed the plug wires it has not been on but the problem remains. Also got it checked at auto zone and the print out they gave me was a long list ranging from possibilities of $1000 repairs to $5 fix, so I do not trust that at all. The print out was not specific as to what specifically was the problem, just a long list of what COULD be the problem.
Like I said I have done plenty of maintenance on this car, new spark plugs not too long ago, new water pump, ALL fluids flushed and replaced (some more than once in the past year), all new brakes, new belt, oil changes on the reg w/ lucus oil additive, lucus fuel additive once a month, just about all of the a/c system is new, etc, etc...
I was thinking is it possible that the fuel filter is clogged causing this? I replaced it too but that was over 30K ago.
Old 07-08-2010, 04:24 PM
Again, WHAT ARE YOUR CODE #s?
Old 07-08-2010, 10:21 PM
Post the codes if you have them and also check under the hood to see if you have any vac leaks. I agree with the description you gave of the Auto Zone read out at this point! Could be a $1000 problem or a $5 problem.
Old 07-11-2010, 03:44 PM
Sorry don't have the code print out anymore, so I don't know the code. It has been a week and the check engine light has not been on sense. Although the car still has a rough idle and it has no power when you try to accelerate, it does not do this all the time. Only about half the time I drive it, it does that. So I really don't know what it could be.
What do you guys think? Coils? Maybe the Crank position sensor? ???
Old 07-11-2010, 11:48 PM
You really need to get the codes read again. Otherwise, you could spend alot of money guessing. Could be coil packs, fuel related issue, sensor or even cat needing replaced.
Reply
Thread Thread Starter Forum Replies Last Post
miss fire dan602 93-02 General 17 04-02-2015 09:56 PM
Engine running rough / Won't idle keaboi 93-02 V6 Tech 6 10-06-2011 11:25 PM
Engine misfire, EGR replaced still rough idle! JaDARaD8* 93-02 V6 Tech 9 04-29-2009 02:01 AM
miss fire help hevymetalg 93-02 V6 Tech 2 12-06-2008 04:16 PM
Miss fire legacyin07 General Tech 18 11-26-2007 07:11 PM
Tags
2000, 2010, 98, accelerate, cam, camaro, check, fire, idle, ls3, miss, power, rough, slight, ss, uneven, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
