connecting rod bearings
Old 04-09-2011, 07:08 PM
mastrmasn75's Avatar
Default connecting rod bearings
I have found out that my camaro needs the bearings for the connecting rods, but goto my local parts store, and their is like 12 different styles. I have the 3.8 liter series two. 99 camaro. any help here in what I need. Thanks
Old 04-10-2011, 06:27 PM
First of all you need to determine if the crank journals need a regrind, then in ant case the journal have to be measured to get the right size bearings that will provide the proper clearance. If you have a perfect crank, and you plan to drive sensibly, then you can go with just about any type bearing of the proper size, otherwise pay the extra money and get a good set of trimetal bearings. If the rod bearings are shot, then the mains won't be far behind, so change them all.
98v6ttop
10-14-2013 07:31 PM
emptysmile005
02-23-2011 04:33 PM
pimpjuicepd
07-08-2009 11:36 AM
sewerrat
08-06-2008 02:41 AM
lennyob
11-02-2007 02:53 PM
Quick Reply: connecting rod bearings
