Change proportion valve for 98-02 rear disc brakes onto 95 3.4L rear drum?
Old 10-25-2007, 12:47 PM
libertyforall1776's Avatar
Default Change proportion valve for 98-02 rear disc brakes onto 95 3.4L rear drum?
Anyone know if I have to change a proportion valve to add 98-02 rear disc brakes onto my '95 3.4L which currently has rear drums? Any other modifications needed? New Master Cylinder?
Thanks in advance.
The image is of the type I want to add:
Old 10-28-2007, 07:15 PM
Default RE: Change proportion valve for 98-02 rear disc brakes onto 95 3.4L rear drum?
*bump*
anyone?
Old 10-28-2007, 07:32 PM
Chappie99's Avatar
I put a 95 Z28 disc rearend in my 99, didnt need to change the valve, but I did go from disc to disc. I am almost positive you should have to.
Old 10-28-2007, 07:54 PM
Do you know what the behavior would be if I did *not* put a new proportioning valve in?
Old 10-28-2007, 09:22 PM
If this helps any, AC Delco lists the same proportioning valve for both rear drum or rear disc, PN 18020589.
Old 10-28-2007, 10:01 PM
Chappie99's Avatar
So I guess its a no.
Old 11-10-2007, 03:04 PM
97rsturbocamaro's Avatar
from what im told from chevrolet, you dont need too, just make sure your hand brake hooks up to the same spot and everything fits well and goes where its suppose to, but your best thing is to either say **** it and try it or go to a well known chevy shop in your spot and ask them. im about to do the same thing but from what im told you dont need too.
camarodude77
12-16-2015 05:52 PM
John 69 Camaro
12-09-2015 11:43 AM
Badrs2810
82-92 V8 Tech
06-17-2010 07:50 PM
libertyforall1776
03-17-2008 03:42 PM
JOHNANDJEN
05-08-2007 08:30 AM
Quick Reply: Change proportion valve for 98-02 rear disc brakes onto 95 3.4L rear drum?
