camaro 3.8l upgrades
Better shocks, like Koni STR.T or Billsteins, Strano 35/22mm hollow sways (or SS sways if you are on a budget, I am selling a set, btw!) -- these alone or together will make a big difference in how the car handles.
You can also get a lot of ideas here:
http://www.camarohomepage.com/project/index.htm
There are many places you do NOT want poly. About the only place it's ok is in sway bar end links & body mounts. Poly also transfers vibrations a lot more than rubber -- keep that in mind.
best bang for your buck would be to have it tuned for your mods. not sure if solomon LT1 PCM Tuning - Welcome! or pcmforless Home | PCM for Less does your year. have a look.
