Changing AC compressor
Old 04-15-2008, 07:30 AM
EDGE's Avatar
Default Changing AC compressor
Hi,
the AC compressor on my 93 v6 is making a whole world of noises, I think its the clutch thats gone bad in it so I've picked up a second hand one from a junk yard. I've also got the hose assebly that connects to the back of the compressor and comes up and joins near the firewall (the hose with the refill valve on it)
In the Haynes manual it says that you need to drain the old compressors oil in to a container to measure it, then pour the same amount of oil into the new compressor... now.... this aircon oil is very difficult to buy over here in the UK so I was planning on swapping the pump and hose at home and then driving to an aircon cnetre and hving them regass the system. My questions are:
Is gassing the system enough to put the oil back in the compressor?
Is it safe enough to use the car with no oil in the compressor?
Anyone done this before and have any tips?
Thanks
EDGE
Old 04-15-2008, 08:04 AM
02StanGT's Avatar
Default RE: Changing AC compressor
If you run it without oil, the compressor will just burn up. Some places that sell refill kits, sell some that comes with oil mixed with the refrigerant. If ever unsure of what you're doing (even after getting our advice) take it to the shop.
Old 04-15-2008, 10:05 AM
EDGE's Avatar
it'd only burn up if i tried running the ac though surely? And with no gas in the system the low pressure switch should stop the compressor sharft turning shouldn't it? Shouldn't the pulley just free spin on the shaft?
Old 04-15-2008, 11:16 AM
02StanGT's Avatar
You're right. I thought you were talking about using the A/C with no oil.
Old 04-16-2008, 05:04 AM
EDGE's Avatar
ah, no....sorry, i didnt say that clearly i gues.. I wouldn't use the a until it was oil'd and gassed
DashingDaryl
05-21-2012 07:11 PM
Mesosneaky
08-18-2009 08:42 PM
bond67
08-19-2008 08:29 PM
fbjunior
05-10-2007 05:23 PM
jbassiii
10-02-2006 04:55 PM
Quick Reply: Changing AC compressor
