98 V6 Airbag fuse?
98 V6 Airbag fuse?
My airbag light flashes 7 times like it is suppose to, then stays on steady. Can anyone tell me which fuse on the IP is the one for the airbag system? I left the little panel that tells what the fuses are down at the shop an hour away. I scanned it for codes using a Actron CP9180 autoscanner and only code I am getting is for an oxygen sensor. The "check engine soon" light came on this morning. Will I even get a code if the system is showing disabled?
ladybridgeport
04-05-2010 08:44 PM
