500hp soon to come!!!
I just ordered some new parts!
Comp Cam: 218/218 548/548 114
Comp 918 Valve springs
Comp. Push rods
Titanium retainers
Valve seals
Comp OE lifters
ARP heads studs
Cometic .074 head gaskets
Cam gaskets
This should boost me over 500HP
Comp. Push rods
Titanium retainers
Valve seals
Comp OE lifters
ARP heads studs
Cam gaskets
RE: 500hp soon to come!!!
You gotta get that 60' time down from what I saw posted on some other link to pictures of your car (mid-high 13s at 106 with a 2.4 60' time) or the power won't do you as much good asyou might hope. You are running 315s but are they drag radials? That might help. You should be running high 12s if you have 425 HP now, and low 12s/high 11s with 500, if you can get the '60 ft to around 1.8 or better.
Thanks for the advice. The times i ran were on my old turbo set up. I was at 330RWHP then, the car was not tune properly and I was running on 245 street radials. Additionally, It was my first time ever to the track. Since then the car has been up and down for different things. The mods above were not planned. I blew the head gasket do to a wiring harness problem. I figured that since I was taking the heads off I would go ahead and upgrade the valve train and toss in a cam. New times hopfully next month ...
Patrick
Sick Sixx Member
97 Mystic Teal Camaro
400+RWHP
Old setup Track time:
13.9 @106
Mods
Patrick
Sick Sixx Member
400+RWHP
13.9 @106
Mods
