Which Scanner do i need
Old 06-10-2008, 04:53 AM
DaveyM's Avatar
Default Which Scanner do i need
Hey all,
I have a 96 3.8 v6, i'm in Ireland so scan tools are hard to find, Which one do i need, the connector is 16 pin type with pins 2,4,5,6 9 and 16 occupied.
Thanks
Old 06-10-2008, 08:45 PM
typeomang's Avatar
Default RE: Which Scanner do i need
You will need a OBD 2 scanner, check out summit.com, also autozone.com has one.......SFC
Old 06-15-2008, 08:12 AM
DaveyM's Avatar
Thanks for That,
I have obtained an ELM327, i have a few programs which report no DTC error when the MIL lamp is flashing, if i clear codes it stops but starts again after a minute or so. Should Lamp be constant? in order to get an error?
Thanks
Dave
Old 06-15-2008, 10:55 AM
Flashing MIL light is "usually" an indication of misfire.
iLL95
12-09-2011 09:02 PM
old timer
07-11-2011 04:26 PM
skinut
12-12-2010 12:52 AM
Matt94
10-14-2010 04:26 PM
ryguy425425
02-17-2010 11:18 PM
Quick Reply: Which Scanner do i need
