1995 3.4 v6 camaro
1995 3.4 v6 camaro
I am changing the water pump, and can not get power steering bracket removed. Have removed all foreseen bolts and removed 1 coil pack for bolt behind, but can't get socket on it, because lower coil mount plate is 1/16 higher than bolt head. I'll probably change steering pump too, because of pain of removing all this. Anybody run into this problem before?...I need Help
go here download the factory shop manual for the 94fb. http://www.mediafire.com/?40mfgeoe4ctti its pretty much the same as 95. should help
