1994 camaro 3.4 v6 Alternator
Can't say for sure, but you probably will need the regulator. The problem could be a shorted or open diode(s) (first kit 03) or a bad regulator (03-2) or more likely, both. And to replace the diode pack, you will need a high-powered soldering iron (at least 150 watts)
