Transmission pull/replace clutch fork
#26
the rod that goes from the peddle to the master cylinder. it should be threaded on one end. dont want to over adjust it and bottom the piston out. are the brake and clutch peddles even
#27
the clutch pedal is about a 1inch further down than the brake pedal. with the car off i can put it in 1-6 and reverse no problem with the ignition turned on the only gear i cant get into is reverse. I am thinking maybe its my reverse lockout solenoid?
#29
is there any play in the peddle? should be a tad of play before the shaft is ingauged. need to get the full travel with new clutch. will it go into reverse with engine not running.
#30
there is no play in the pedal, it feels exactly how it always felt before it broke. It will go into reverse with engine not running.
