clutch is soft with grinding noise
#21
Pull the slave cylinder and the adapter piece it bolts to and try pushing on the clutch fork with just your fingers. You shouldn't be able to move it. Try wiggling it if you can.
The only think that makes me rethink that it's not a broken fork is you said the pedal returned after pressing it down. When the one of mine broke, the pedal was stuck to the floor.
#24
Because the broken fork wasn't putting pressure against the slave cylinder and in turn would be returning hydraulic pressure back against the master cylinder and pushing back on the clutch pedal. With nothing connected to the pedal, the pivot/coil spring on the pedal assembly (when working) will bring the pedal back up. Without a spring, you have the weight of the pedal leaning on the master cylinder.
#26
according to the book yes you have to take trans out. found this while searching http://bfranker.badz28.com/fbody/t56.htm
#27
Lucky for you, you can get a reproduction clutch fork now. Couldn't get them a few months ago when mine snapped. Price isn't too bad honestly. Before you couldn't find one under $500.
Fork
Clutch Fork, Camaro/Firebird 93-97 T56 LT1 5.7L V8 Clutch Release Fork, HAWKS - Hawks Third Generation
Fork w/ t-bar
Clutch Fork Kit w/ Pivot T Nut & Bolt , Camaro/Firebird 93-97 LT1 V8 5.7L HAWKS - Hawks Third Generation
Fork
Fork w/ t-bar
#28
according to the book yes you have to take trans out. found this while searching T56 Clutch Install Notes
#29
Fork
Fork w/ t-bar
Fork
Fork w/ t-bar
