Easter tie rod replacement
Old 04-16-2017, 02:45 PM
94MaroMuscle's Avatar
Default Easter tie rod replacement
When replacing my 23 year old outer tie rod, ran into a couple of rusting issues, most likely will have to cut it off. I now am just replacing the whole inner and outer but ran into another unseen circumstance, there seems to be a rubber casing on the top part of inner tie rod. Has anyone run into this, and can I just remove it by prying off with a thin flat head screwdriver? I have the tie rod removal tool but don't know if I should attempt to remove it with the casing in place of move it out of the way.
Old 04-16-2017, 07:17 PM
took care of it, just a rubber boot, just remove it.
Mylolz
01-15-2013 07:58 AM
osduck5
04-30-2010 09:18 PM
camaro girl
10-27-2008 09:53 PM
djschick88
08-22-2008 08:52 PM
bluovlh8er
03-07-2008 12:53 AM
Quick Reply: Easter tie rod replacement
