Replacing Shock Mounts
Old 11-23-2013, 10:37 PM
libertyforall1776's Avatar
Way overdue on those shocks!
If the car is not sagging, then your springs are likely ok.
Originally Posted by Z28Camaro98
I replaced all 4 shocks on my Z. Front had about 205,000 on the originals. The rears i changed earlier at 195,000. MAde a huge difference. Should I have replaced the springs also?
Old 06-17-2015, 03:51 PM
gagger84's Avatar
Originally Posted by libertyforall1776
Yes the mounts come with the isolator. Use the OEM ones, all aftermarket ones including Napa's are not as beefy.
You should also consider the new Koni STR.T shocks, about the same price range as Bilsteins.
Strano Performance Parts - Part Details
Where is the best place to look to buy the OEM mounts?
Old 06-18-2015, 10:47 PM
^ Try eBay, Google/Bing Shopping, Amazon, OEMcats.com
Old 06-19-2015, 03:21 PM
gagger84's Avatar
I appreciate the help, thank you!
Old 03-09-2016, 10:59 AM
gagger84's Avatar
I know I'm reviving an old thread, but I bought some Bilstein shocks and need a spring seat as well and I'm thinking about going with the Moog ones. These should fit with the Bilsteins correct? Also, are the Moog seats just a 1-piece item or do I need to buy something else besides the seat itself? I'm just curious because the Monroe Strut-Mate Coil Spring Insulators (904962) appears to be a 2-piece component on Summit.
Just a bit confused as to what I all need to complete the whole new assembly. I would like to put the new assembly together before ripping the old one out as I don't plan on reusing any of the original parts. So far I have:
-Bilstein shocks
-Strano Springs
-New upper shock mounts
-New upper shock insulators
Also, is a dust boot required? And any brand recommendations on those?
Thanks!
Old 03-09-2016, 12:23 PM
Old 03-09-2016, 12:24 PM
liberty got new ones with his maybe he still has the old ones.
Old 03-09-2016, 12:27 PM
gagger84's Avatar
Originally Posted by craby
And that's all I should need, correct?
Old 03-09-2016, 01:40 PM
as long as you got the correct shocks with the things on the shock to hold it from falling all the way. what happened to the ones off the shocks on the car?
  #20
Old 03-10-2016, 08:40 AM
gagger84's Avatar
Everything I got, I order from Strano so I'm assuming its all correct, and the rear shocks/springs went on great. I was thinking new spring seats would come with the Bilsteins, but I was definitely wrong on that end. The factory spring seats are still on the car - along with the original DeCarbons. I would prefer to install a whole new assembly as some of the original parts are fairly rusted thanks to good ol' MN winters.
Planning on putting the new assembly together, removing the old, and installing new as one unit that way I can start work on it before pulling the car out of storage (hopefully next weekend).
BZpbp
01-15-2012 02:54 PM
BigBen762
08-25-2011 10:28 AM
v6baser
02-15-2011 10:40 PM
Quick Reply: Replacing Shock Mounts
