Replacing Shock Mounts
Old 10-29-2013, 12:01 PM
UFGatorFan's Avatar
Default Replacing Shock Mounts
My shock mount just went bad and I can hear it banging at low speeds over bumps. I had already planned on doing new shocks allaround, now new mounts have been added to the list. I was looking around at diff mounts. The concesus is that moog is the ones to go with. Is that true? Also when you buy the mont does it come with the isulator? (I think that is what it is called.)
Old 10-29-2013, 01:29 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Diff mounts? There is no mount for the rear differential. Our cars have a 3-link suspension system (Panhard, lower control arms, and torque arm). Which bushing are you referring to?
Old 10-29-2013, 01:59 PM
UFGatorFan's Avatar
"Different mounts". sorry. I am talking about the upper front shock mounts.
Old 10-29-2013, 02:53 PM
How many miles on the car? By the time the rubber bushings are shot, the shocks have seen better days as well. Since you would have to unbolt the shocks to replace the bushings/mounts anyway, that would be a good time to go ahead and replace the shocks.
Old 10-29-2013, 03:09 PM
UFGatorFan's Avatar
Car has 160000 miles. I plan on replacing the shocks as well. Those strano bilsteins are the ones I am looking at. I have never replaced a mount before so I am trying to figure out if the mount comes with the insulator/ isolator.
Old 10-29-2013, 04:13 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Since your car has so many miles it may be a good idea to just overhaul the springs too, since theyre probably worn. You could probably do shocks, springs, and mounts for around $700 and it will ride like a new car, plus you wont have to fight getting the old rusted spring mount off the old shocks.
Old 10-31-2013, 01:17 PM
Z28Camaro98's Avatar
I replaced all 4 shocks on my Z. Front had about 205,000 on the originals. The rears i changed earlier at 195,000. MAde a huge difference. Should I have replaced the springs also?
Old 11-22-2013, 08:41 PM
libertyforall1776's Avatar
Lightbulb
Yes the mounts come with the isolator. Use the OEM ones, all aftermarket ones including Napa's are not as beefy.
You should also consider the new Koni STR.T shocks, about the same price range as Bilsteins.
Strano Performance Parts - Part Details
Old 11-22-2013, 08:58 PM
is new koni non adjustable?
Old 11-23-2013, 10:29 PM
Lightbulb
Correct, it is somewhat similar to a Bilstein, lower cost option.
They are orange, so color is now no longer the only question to ask to know what shocks someone has.
Comparison of OEM de Carbon/Delphi and Koni STR.T:
Quick Reply: Replacing Shock Mounts
