Replacement Strut Mounts
Old 03-22-2016, 07:52 AM
gagger84's Avatar
Alright, I think I got a better idea of what needs to be done. Was hoping to start working on it tomorrow, but its supposed to be a crap-shoot weather wise. It'll just have to wait until this weekend.
Thanks again everyone!
Old 07-18-2016, 02:24 PM
gagger84's Avatar
Been a long time coming, but finally got the suspension installed and the car back on the ground. Now just need the front end to settle...
Old 07-18-2016, 02:26 PM
gagger84's Avatar
Another picture...
Old 07-18-2016, 03:53 PM
95 camaro 406's Avatar
Default ?
what do you meen bye settle did you lower it , with my 95 I am doing oem mounts rubber coated ,an doing just the struts in front an the upper ball joints an inner tie rods ,an lower ***** too if I choose to ,since I got air shocks in back for now just doing bump stops ,in front will paint the springs an upper control arms vht works great ,I went with stagg for the front makes a desent track slash street shock $300.00 includes the shocks upper lower ball joints, tierods inner outer, shock mounts an the $25,00 bump stops red,will just use the old stop for the plate for the 17 inch wheels ,anything is better then the 21 year old stuff there now ,did you do upper ball joints an tie rods inner too,i got all greaceable ball joints is why I may do them all I am not lowering my car though ,should be an all day job .going to repaint the calipers to red vht
Old 07-19-2016, 10:06 AM
Lakerman62's Avatar
I use Moog bushings/ball joints, Strano is great! Bought Koni Orange SRTs for all 4 from Sam, in the rear UMI connectors& Founders LCAs/panhard bar, sway bar bushings by energy suspension LS1 front brake conversion, happy so far
Old 07-19-2016, 05:05 PM
looks good, what size wheels and tires you got?
Old 07-21-2016, 02:38 PM
you guys are spending a lot of dough though are you raceing ,I meen what I got for $300.00 again is better then stock thrifty not cheap hehhe,an the 20 year old struts now ,you got to be in over 1grand for what you got ,does look great though ,I know I will also be in over a grand to but thats after pan hard bars body conectors an some others things too like slotted rotors an new axles ,but I am not raceing either ,guess its just choise ,I like bang for my buck an the stagg has a life time warranty too but for about $1500.00 will be struts upper ball joints loweres inner outer tie rods pan hard bars axle rear bump stops an build my rearend to handle 500 hp ,saveing about 1k to 1500,00 over the cost of moog blistien koni ,to me most important is the struts for mild race to street for $125.00 ,what more does one need for the street moog strut mounts are 100.00 for set alone I bet my set are just as good for $40,a set ,theres one side life time warranty on all too
Old 07-22-2016, 10:29 PM
stock shocks on the 4th gen are actually pretty good shocks for there time. and yep the cheap shocks work ok, not as good as koni or bilsteins. sams bilsteins are valved for the 4th gen and the set with springs is tuned for the 4th gen, i believe thats what he got.
Old 07-23-2016, 12:23 PM
an what I got is better then stock too ,hehhehe heck only thing I realy need is the struts done, but done right one should do upper ball joints an inner tie rods atleast couse there apart when one does the struts ,but why not do it up an replace all with time is my plan,my stagg struts are above stock for a lot less mild track to street to $100.00 shipped ,I looked at gabriel full sets with springs an all for $110,00 each wich saves install time ,but on these cars its the strut that goes not the springs, all my springs are still good,just need paint red
JeepGuy12
10-12-2010 03:00 AM
rozellcoair
09-12-2010 09:32 AM
anthonys95
09-05-2010 01:45 PM
libertyforall1776
08-07-2008 07:30 PM
350rs
11-10-2007 11:32 AM
Quick Reply: Replacement Strut Mounts
