Socom's LT1 -> LS1 Swap Thread!
Updating with some pictures, she's coming along! I got the fuel system done and the wire reinstalled to the starter from the battery in the trunk. I converted the return system to a single -6 AN line from the stock fuel filter location using a vette filter/regulator. I got the Pontiac column in as well since my wheel was really old and bad looking, so I figured I would swap them. Plus I'll be able to have two sets of keys for my car now
Looks nice. Just curious, what's your clearance like between your exhaust, drive shaft, and torque arm? I've been debating on getting the aluminum drive shaft but I'm thinking it'll hit the exhaust. Even with my steel shaft, I either gotta remove the exhaust or the torque arm to get it out.
Here's another update for everyone! The car is alive Just been fighting getting the clutch bled but after that it should be ready to hit the streets! Two videos below for your listening pleasure.
Here's the finalized engine bay with all of the wiring tucked as it should be, and the strut tower brace in place.
Did you get the clutch bled? I had issue getting my LT1 bled. Funny part was I got so annoyed I walked away for 2-3 weeks, when I finally went back to it I got in the car and the clutch felt great. I guess it gravity bleed or it just did not like the fact it was dry for awhile.
y pipe
i wonder why guys keep going with those that's 2 into one into 2 ,for me its restricted so much power ,true duals are like having open headers ,for me it was making my car shake an holding back a lot of air ,an now it just seems right ,I guess I just don't see to many guys going with them hear ,but other places they are ,mabey its just the difference in set ups that the lt1 was made for all the pollution control ,an the 406 not realy being carbed , then sone guys don't like a realy loud exhaust either
#20
Too buy a nice true duel system for our cars is a couple grand vs the couple hundred for the Y-pipe set up. Yes, one can fabricate it themselves, but why? It's not necessary for our cars. A full 3in exhaust till it hits the tail is more than enough. I tried doing the duel exhaust system on my car. It sounded awesome, but my mufflers scraped from sitting so low. Granted, that was on old worn out springs. I'm sure I'd have pop can clearance now with the new springs.
Looks and sounds good Socom! Keep it up.
