Project Basic Bish
#33
you would need to do mods on the truck unit. its too wide for one so would have to be cut down. if you have a machine shop you could do it. all brackets would need to be removed and ones that match the stock unit welded on in the right places and at the right angles. stock 10 bolt will handle some pretty good hp, not 800, so long as the tires are not sticky,,, and you have auto trans.
#34
thats big money your putting in this car ,are you thinking about super charger ,I know how my friend will make 2015 challenger make 1000hp ,right now its stock 610hp he will get 300hp with the super charger an few bolt ons to get near 1000hp ,but he also spent like $46,000 for the car ,an its like $7000.00 for the charger ,he likes to go fast said 150mph feels smooth ,hes due for a ticket too,an owns a restaurant so I guess that how he Affords it,pulled pork good stuff to 408 makes 6.7 L darn close to 6.8 mine is near 6.7 at 406 ci,but not close enough yours would be,seen 408 stroker ls3 all forged 650hp $10.900.00 ,is not bad ,though I am pretty sure you can build it ,that's not bad for that kinda HP
#35
#36
Actaully I checked out that engine an for $10.900 for what you get its not a bad price ,you get all every thing ,more then I got for my turn key ,the whole belt assembley Ac starter fuel injection water pump power streeing ,only thing you don't get is the wireing harness other wise its a true turn key an for that price you get a lot ,mine was 7000.00 after all the pulleys a mock ups an trany too though,a belt assembley can cost $2000.00 alone,though I relize I could have got fuel injected engine for about the same an saved some head aches live an learn
#38
yes the 6.0L is 366 Ci engine so if your going with 408 6.7 L ,your boring that 6.0 out to get 620 hp ,an the one I was looking at for 10.900 with everything is 427 7.0 ,you will part an engine together for a lot more then that ,that's a project bish
