Project 93
#41
lol, he may have been reefering to the racing stripes on the tars. Are the green stripes in a wear area, or will those stay there? Or maybe those are there to monitor how hard you corner!
#42
Not sure why they are there, I never bought Pirelli tire before and I got them from the tirerack.com so I never saw them before they showed up. I would guess they are wear indicator do they know if the tire was run on the road. I expect them to go away quickly
I am thinking about blacking out the rims. I saw a black Vet the other day that had blacked out rims with a single red line around the rim and red calipers and it look bad a##.
#44
stupid rain. lol, yep the stripes on the tires, haven't seen them before so i figured it had to give more power. i would leave the wheels for now and let some time pass and see how you feel. i like a black car with some bling at the wheels. might try blacking the inside of the rim, can't keep that part clean anyways.
#46
Thanks for that post, that is another option. I think the rim original called black chrome. The factory black smoke has faded but still there in spots.
This is the first time I have seen the rims on the car with the engine installed. Does it look lowered? I have not done a real shake down run due to alignment but it sure starts easy and runs smooth.
#48
Heater core is all sorted out, When I pressure tested the system I found a leak at water pump end of the heater hose. No Idea how I missed that on the other pressure tests. I still need to put the glove box back in but my back is killing me. Heater core is not complicated job it just everything is tuff to get too. Once you get the glove box out it is only 4 bolts and 2 hose clamps. Plan on those 4 bolts and 2 hose clamps taking about 2 hours.
#50
ss hood plans for engine
Features
98-02 front clip real SS hood and rear deck ? is that hood fiberglass ,did they make metal one ,I can not find an original ss hood ,an nothing aftermarket that is metal ,were they just all fiberglass,an near all the after market ones want you to use hood pins ,not sure I want to have to use ,hood pins ,are you rebuilding the engine ,how much was the car the way it sat ,I would love to just find a ss hood ,looks good ,though I see now it say 93 project but says 98 02 hood clone ,I know it has to be 93 to 97 hood to work on mine thanks
Features
