My 96 RS build.
My 96 RS build.
02/2005 1996 RS 60k miles
new front nose emblem
bad choice with billet grille
another bad choice on flowmasters and rear euro markers
black outs
inatke and first STB
no pics
32/21 1LE sway bars with poly bushings and endlinks
interior change neutral to ebony and wrapped dash parts.
black outs
no pics
Borla goes in, with corsa clones
dyed top
3 point Kenny Brown STB
other parts with no pics
new J&M Panhard
J&M LCA's 3 piece poly-ball bushing
UMI SFC's
poly bump stops
new hood
finally a tonneau cover
dyed top
new J&M Panhard
UMI SFC's
poly bump stops
new hood
Well after wasting around 3hrs or so, trying to get a lifter out of the oil pan, that I forgot to take out. The new GT2 cam and JP performance timing chain set are finally in. Maybe next weekend we can start this baby up........=:-)
finished the intakes
and where its at now
1996 Camaro RS Convertible
Exterior Color: Arctic White
Interior Color: Netuarl Leather
Engine: 3800 Series II V6
Transmission: Automatic 4L60E
Factory Options:
Fully Loaded
Exterior modifications:
-Harwood 2.5" cowl hood
-Black carbon fiber nose emblem
-Berger mod with white camaro emblem inserts
-Red Calipers
Interior Modifications:
-Ebony leather interoir swap
-Red LEDs in dash
-Custom vinyl wrapped dash and trim
Performance:
-Full cold air intake by chromeintake's
-GT2 Cam
216°/216° at .050"
Intake Lift .317" (.507" lift at 1.6:1 rocker ratio)
Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
111 LSA
-LS6 #90 yellow springs
-Comp pushrods 7.05 5/16 .080" thickness
-Viton Valve Seals
-INTENSE Re-usable Rocker Arm Bolts
-JP Performance Single Timing Chain
-Manley Performance Valvespring Retainers
-Comp OE lifters
-Pacesetter Headers
-Borla PRO XS
-4" Corsa Clones
-NGK TR55 spark plugs
-MSD 8.5MM Super Conductor Ignition Wires #32799
-180 Thermostat
Suspension:
-UMI red SFC's (weld-in's)
-Kenny Brown 3 point STB
-J&M LCA's 3 Piece Poly Ball Bushings (red)
-J&M Panhard Rod (red)
-32mm 1LE Front Sway Bar (black)
-32mm Prothane bushings (red)
-Front Energy Suspension End links set (black)
-21mm 1LE rear sway bar (red)
-21mm Prothane bushings/end links set (red)
-red ploy bumpstops
Wheels/Tires
-17' SS 10 spoke wheels
-275/40ZR17 Riken Raptors
Brakes:
-Slotted and cross drilled rotors
Electronics:
-SLP Fan Control Switch
-Pioneer DEH-P7700MP Head Unit
-Blaupunkt GTc652 6-1/2" Component System
-Blaupunkt GTx662 6-3/4" 2-way Speakers
Factory Options:
Fully Loaded
-Red Calipers
-Red LEDs in dash
Performance:
-GT2 Cam
216°/216° at .050"
111 LSA
-Viton Valve Seals
-Comp OE lifters
-Pacesetter Headers
-Borla PRO XS
-4" Corsa Clones
-180 Thermostat
Suspension:
-red ploy bumpstops
Wheels/Tires
Brakes:
Electronics:
BTW, my car dyno all stock at 170.9 rwhp, and the GT2 cam and mods that I have usually dyno around 225-240 rwhp, I've seen a few with higher numbers, that have been able to get a reall live dyno tune.
Thanks and yes it been a lot of work at times.
