My 96 RS build.
  #21
Old 05-06-2013, 03:13 PM
fbodyrs96's Avatar
That's an optical delusion. The one pipe with the weld is an up and over the rearend for the passenger side. But look closely, the pipe that's to the left and curves below is still open and unfinished. The drivers side tail pipe isn't connected to it yet.
correct.
  #22
Old 05-07-2013, 02:21 PM
WIspartan1026's Avatar
May 2013 ROTM
Ah, I see it now
  #23
Old 12-12-2013, 03:45 PM
I'm sure you did a vinyl wrap for the plastic pieces on the door but did you also replace the upholstery/carpet-y material on the door or dye it?
  #24
Old 12-24-2013, 04:00 AM
fbodyrs96's Avatar
Neither, those are 00-02 gm ebony door panels
  #25
Old 12-24-2013, 09:51 AM
fbodyrs96's Avatar
well after 3 weekends of working on shocks and springs there finally on.
2 AGX 741034 Front
2 AGX 743019 Rear
Moog Front Coil Springs
Moog CC635 Rear Coil springs
Moog K6573 Coil Spring Insulator/Seat-Coil Spring Insulator
Moog K6630 Sway Bar Links front/rear
Moog ES3238RL Outer Tie Rod End
Moog K6516 Strut Mount Left
Moog K6517 Strut Mount Right
Originally I had stranos springs, but I couldn't handle all that bouncing and bottoming out over ever little bump.
who new the seat belt brackets covered up the rear mounts in a vert, such a pain in the ***.
he said it was like christmas morning....lol
  #26
Old 12-24-2013, 09:52 AM
fbodyrs96's Avatar
  #27
Old 12-24-2013, 09:54 AM
fbodyrs96's Avatar
got the moog outer tie rods on.
  #28
Old 12-27-2013, 05:58 PM
May 2013 ROTM
way to put the little guys to work
  #29
Old 04-14-2014, 12:08 AM
fbodyrs96's Avatar
just a few new pics
  #30
Old 04-19-2014, 01:59 PM
Parenting rule #1: get the boys into cars at a young age!
nasstySS
03-21-2012 08:42 AM
Oil guy
04-17-2009 07:41 PM
ShawnB391
04-05-2009 02:11 PM
1981TypeLt
02-19-2009 10:21 PM
gomez101380
82-92 V8 Tech
11-27-2008 11:14 AM
Quick Reply: My 96 RS build.
