MKCoconuts Z28 Project
#181
Honestly, didn't even come to mind until you just mentioned it. I think I can live with it though. Gotta keep something else in the bay since ABS block is going, and a/c is already gone. I got some of the suspension painted, I'll get pics when it stops being -20 out.
#184
Pic time.
K member cleaned and painted!
Headers painted and cured. They will get another cans worth and then wrapped.
Bin of new/painted parts
Inside the cylinders
Heads
#186
#189
Got some more done the last few nights.
Upper Control arms painted
Hood Hinges done
Oil pan
Cam installed, new timing chain/gears, water pump and the opti put on.
Waiting on the valve springs to come in to finish the heads. Was gonna paint the lower control arms last night but got frustrated by the fact that Energy Suspension doesn't include new metal sleeves for the bushings on the front and before knowing that, I had used a torch and air chisel to remove the old bushings...so I called it a night after that. Picked up new bushings from work just so I can burn the rubber out and use the sleeves. Heads up to any one switching to poly bushings, read footnotes and keep all the metal sleeves in good condition..
Hood Hinges done
Oil pan
