Engine swap 1995 z28 350 to 406
#141
somehow your getting the wrong address, all i see is a question mark on yours. i had to use my special powers to look at the links address and go to the utube site and copy.
#143
t is the one wie new headers
old exhaust
this the one,like night an day from the other one ,what you think ? above
click it works now for me s proper air not near as loud old exhaust ,I thought it was ok,but I was not ,there alot more vibration you cant see in video ,its like night an day ,as you see in the first video being now this one was from last year,,i am noticeing so many advantages to the new exhaust ,like that it starts right up ,had to turn down idle was good ,to keep it the way it was would have been a waste of a good 406 ,someone should now like that sound ,that is the video above over this one bye far
#144
click it works now for me http://youtu.be/OljbXeZhaqs s proper air not near as loud old exhaust ,I thought it was ok,but I was not ,there alot more vibration you cant see in video ,its like night an day ,as you see in the first video being now this one was from last year,,i am noticeing so many advantages to the new exhaust ,like that it starts right up ,had to turn down idle was good ,to keep it the way it was would have been a waste of a good 406 ,someone should now like that sound ,that is the video above over this one bye far
#145
GEDC0505 - YouTube
GEDC0505 - YouTube
#148
yes the second video is before ,the first one that sound is an echo yes ,I had an exhaust leak start with the old manifold an exhaust makes sence with the power that was locked up that bothered me to drive it with leak for few weeks knowing all I had done ,?are those cats worth anything I know my old tips are worth like 75,00 as there 150.00 new magnaflow there the 4inch X22in if I had an 18 we could have reuse them I am going to put a double round like 10 inch tip this summer ,,I was told to check the bolts though seems it wont get a leak as easy couse it breaths right now ,the #1 video like night an day you can hear my voice #2 is yes that throaty sound of totally unrestricted I love it ,its a bit low but will work it,as far as video I must not be copying exactly couse that's what I did put the http// then the rest ,I need to get one driving down the road with windows down its loud when you hit the gas ,at steady speeds its pretty quiet but wakes up fast when I hit the throttle ,I am happy to finley feel the power of the 406 ,thanks for getting those loaded ,only make sence I should have put the headers on to begin with ,next I may either move that fuel pump or I have one that went on like roadmaster that would install right where the fuel filter is there much cheaper an run from like 4 to 9 psi an wont be as loud ,right now it says 4,5 psi an seems to run good there ,but for now still about 10 miles per gallon ,it seems to love the octane booster ,definatly no knocking that may have also been couse of lack of air ,it was affecting a lot of things ,so anyone who trys this ,don't reuse old exhaust ,it was $900.00 to do an 3 out 4 of my gauges the volt meter I can put in myself ,so I thought that was good ,concidering some guys spend 1000,00 for headers alone,so yes the first video is the new system ,#2 is old system ,engine looks better now too in#1,then #3 video is of gauges
#150
yes I had some wierd thing happen with youtube ,I opened a page that had a trojen horse ,but I got rid of it right away ,all I did was click on what I though was youtube then this thing comes there ,then its gone ,yes that one is the gauges ,the next will will be drive off ,its running great thank you,it breaths the way is should ,sounds alot better ,no back pressure ,makes for what feels like 40hp easy ,theres no telling how much power was locked up in the old exhaust ,alot ,I meen it made the whole car shake now it just purs with no vibration ,I think headers help but the straight pipes ,make the difference I think I would still have power locked up with the old exhaust ,its no wonder I wanted to go oldshcool ,,now I can turn up the psi from like 4 to 6 psi depending,i am noticeing better gas milage too not a lot but seems to get better if I can get 12 an 15 highway that will be great ,
