Engine swap 1995 z28 350 to 406
Old 05-25-2015, 05:12 PM
somehow your getting the wrong address, all i see is a question mark on yours. i had to use my special powers to look at the links address and go to the utube site and copy.
  #142
Old 05-26-2015, 11:05 AM
95 camaro 406's Avatar
yes it the one before this I am putting the url in hear that's the old one
  #143
Old 05-26-2015, 11:06 AM
Default t is the one wie new headers
old exhaust
click it works now for me s proper air not near as loud old exhaust ,I thought it was ok,but I was not ,there alot more vibration you cant see in video ,its like night an day ,as you see in the first video being now this one was from last year,,i am noticeing so many advantages to the new exhaust ,like that it starts right up ,had to turn down idle was good ,to keep it the way it was would have been a waste of a good 406 ,someone should now like that sound ,that is the video above over this one bye far
this the one,like night an day from the other one ,what you think ? above
  #144
Old 05-26-2015, 11:15 AM
click it works now for me http://youtu.be/OljbXeZhaqs s proper air not near as loud old exhaust ,I thought it was ok,but I was not ,there alot more vibration you cant see in video ,its like night an day ,as you see in the first video being now this one was from last year,,i am noticeing so many advantages to the new exhaust ,like that it starts right up ,had to turn down idle was good ,to keep it the way it was would have been a waste of a good 406 ,someone should now like that sound ,that is the video above over this one bye far
the link works when I am online hear ,thanks craby this one to one above big difference,thanks still not sure what I am doing wrong I am putting the url into pictures link,this was the one with old exhaust ,an big difference ,that one above looks sound a lot better
  #145
Old 05-26-2015, 12:03 PM
GEDC0505 - YouTube
? so in the link what # goes in there ,that's what 458tlbs sound like .compearing other video is none ,I think it awesome
  #146
Old 05-26-2015, 05:21 PM
should look like thishttps://youtu.be/OljbXeZhaqs copy and past and site should add the http stuff.
  #147
Old 05-26-2015, 05:29 PM
sounds good and healthy. almost sounds like theres a exhaust leak but recording can do that.
  #148
Old 05-27-2015, 11:05 AM
yes the second video is before ,the first one that sound is an echo yes ,I had an exhaust leak start with the old manifold an exhaust makes sence with the power that was locked up that bothered me to drive it with leak for few weeks knowing all I had done ,?are those cats worth anything I know my old tips are worth like 75,00 as there 150.00 new magnaflow there the 4inch X22in if I had an 18 we could have reuse them I am going to put a double round like 10 inch tip this summer ,,I was told to check the bolts though seems it wont get a leak as easy couse it breaths right now ,the #1 video like night an day you can hear my voice #2 is yes that throaty sound of totally unrestricted I love it ,its a bit low but will work it,as far as video I must not be copying exactly couse that's what I did put the http// then the rest ,I need to get one driving down the road with windows down its loud when you hit the gas ,at steady speeds its pretty quiet but wakes up fast when I hit the throttle ,I am happy to finley feel the power of the 406 ,thanks for getting those loaded ,only make sence I should have put the headers on to begin with ,next I may either move that fuel pump or I have one that went on like roadmaster that would install right where the fuel filter is there much cheaper an run from like 4 to 9 psi an wont be as loud ,right now it says 4,5 psi an seems to run good there ,but for now still about 10 miles per gallon ,it seems to love the octane booster ,definatly no knocking that may have also been couse of lack of air ,it was affecting a lot of things ,so anyone who trys this ,don't reuse old exhaust ,it was $900.00 to do an 3 out 4 of my gauges the volt meter I can put in myself ,so I thought that was good ,concidering some guys spend 1000,00 for headers alone,so yes the first video is the new system ,#2 is old system ,engine looks better now too in#1,then #3 video is of gauges
  #149
Old 05-27-2015, 09:55 PM
woh all i did was copy and paste and it shows for me. weird. lol, my headers was about a g
  #150
Old 05-28-2015, 11:03 AM
yes I had some wierd thing happen with youtube ,I opened a page that had a trojen horse ,but I got rid of it right away ,all I did was click on what I though was youtube then this thing comes there ,then its gone ,yes that one is the gauges ,the next will will be drive off ,its running great thank you,it breaths the way is should ,sounds alot better ,no back pressure ,makes for what feels like 40hp easy ,theres no telling how much power was locked up in the old exhaust ,alot ,I meen it made the whole car shake now it just purs with no vibration ,I think headers help but the straight pipes ,make the difference I think I would still have power locked up with the old exhaust ,its no wonder I wanted to go oldshcool ,,now I can turn up the psi from like 4 to 6 psi depending,i am noticeing better gas milage too not a lot but seems to get better if I can get 12 an 15 highway that will be great ,
Quick Reply: Engine swap 1995 z28 350 to 406
