Can I fit a 383 stroker in a 94 or 96 Camaro RS?
Old 02-24-2015, 09:24 PM
Artieandsam's Avatar
Default Can I fit a 383 stroker in a 94 or 96 Camaro RS?
I have bought 2 Camaros. 1 is a 94 RS with a 6 cylinder and a tranny that slips. The other is a 96 with same problems. I have always liked the power of a 383 stroker engine. Before I start buying parts to build my 383 I want any and all advise.
Old 02-24-2015, 11:28 PM
MKCoconuts's Avatar
Flip the two cars you have and find one with a V8 already in it. You'll be steps ahead. To swap a V6 to V8 or even a V8 to a different V8 is A LOT of work and decreases the value of the vehicle. If you are dead set on going the 383 route but using the current vehicles you have, read through these threads.
https://camaroforums.com/forum/93-02...0-406-a-77465/
https://camaroforums.com/forum/93-02...-thread-68658/
After reading through those, if you still want to proceed, we will help guide you, but plan for a lot of money, time, and beer because it will not be an easy road. BTW, a 383 (at least by GM engines) is a 350 engine with a .030 over bore making it 4.030 with a 3.75 inch stroke. Compared to a 350s 4.000 in bore and 3.48 inch stroke.
Old 02-25-2015, 06:42 PM
Yes I am aware of the time and money and beer it will take. I choose the 383 because I knew it was just a rebuilt 350. I thought that would be easier than any other engine. I am very lucky so far and my wife is wanting this also. I will appreciate any and all help. Thank you
Old 02-25-2015, 06:43 PM
What Craby said and just a FYI GM did not make a 94 RS
Old 02-25-2015, 08:01 PM
You are right. My bad the 94 is not an RS.
Old 02-25-2015, 08:03 PM
I am thinking the 94 will become my stock vehicle and the 96 will be my project
Old 02-25-2015, 08:26 PM
The 3.4 with a 165 HP at the crank and 3400 lb car are not real fun car to drive. The 3800 should be a full second faster in the 1/4 mile. Still not a fast car by any modern standard but the 200 HP at the crank is little closer. If you are going to cut one of them up for a 383 and make one a driver then fix the 3800 and cut up the 3.4 for your project. The 3800 even gets better fuel mileage.
Also many 3800 parts are still produced and many parts off the FWD version interchange including the whole engine. The 3.4 was only put in the Camaro and only 1993-95 so if you have an engine problem there is not a lot of option. If you decide on a used transmission for the 94 it needs to come from a 94 only I think the 96 will take any OBD11 trans 96-2002
Old 02-26-2015, 02:10 PM
95 camaro 406's Avatar
so the 94 is a z28 yes you got alot of work ahead,value is what its worth to you ,so many guys get raped up in value ,we all know ,hardley anyone gets what they put into a car rarely ,good luck ,keep us updated
Old 02-27-2015, 08:22 PM
His 94 is a V6 not a Z28 so he will need the V8 K frame in addition to all the other stuff.
Old 06-08-2015, 12:50 PM
ok not sure if it just certain years like the 98 to 02 ,let wait for an answer ,you can look at a v6 to v8 swap ,an a 5.3l from a chevy truck works ,but any swap takes alot of no how ,an work
jimcates3
10-05-2012 09:09 PM
BlakeConnerRod
82-92 V8 Tech
12-17-2010 09:04 PM
Matt.Thomas
09-12-2009 11:32 AM
sshogun
06-04-2006 10:36 PM
Quick Reply: Can I fit a 383 stroker in a 94 or 96 Camaro RS?
