2000 v6 engine change
Old 01-13-2017, 10:24 PM
ahh new parts, obx mid length headers and new heater hoses.
like gorn said the bolts are too short
Old 01-20-2017, 05:14 PM
95 camaro 406's Avatar
looks like its comeing along good for you i like my v6 in traffick much better then the 406
Old 01-20-2017, 10:06 PM
What was you source/cost on the heater hoses?
Old 01-20-2017, 11:44 PM
150 bucks on ebayb
Old 01-28-2017, 11:03 PM
If you need any 3800 stuff, hit me up. I've got tons of leftover parts
Old 02-07-2017, 06:43 AM
80sz's Avatar
Like the build
Old 03-16-2017, 12:11 PM
sent the injectors from the blown engine in to be cleaned and flow tested at doctor injector in tacoma. two of them are toast, leaking constantly, poor spray and flow. shop was really good about it and just charged me only cleaning and flow testing for the new/rebuilt ones. 20 bucks each including shipping. same shop tested new injectors for my lt1 and found two of them needed adjusting as they did not flow within the range called for by factory and spray pattern was poor. never assume your injectors are working right, even new ones, most certainly new ones from internet.
Old 03-30-2017, 10:33 AM
almost ready to go back in
Old 03-30-2017, 08:32 PM
transmission is in getting front and rear seals, also they will look at it and see if it needs more. gotta pull the pump to change front seal so he said they can see inside and get an idea of its condition. having rotors turned if theres enough meat left and some new hawks pads.
  #20
Old 04-13-2017, 08:48 PM
well trans was on its last legs, blew my budget. complete rebuild with all weak points replaced. if it wasnt worn out it was ready to bust, 1800 bucks, dang it. it will be stronger than stock, i guess ill have to drive it more...
Quick Reply: 2000 v6 engine change
