Old 02-26-2015, 02:24 PM
95 camaro 406's Avatar
why not while your right there just put a whole new set in ,you can get them resonable,check the crank while your there ,theres no telling what other damage there could be ,just an idea ,
  #722
Old 02-27-2015, 12:04 PM
WIspartan1026's Avatar
May 2013 ROTM
There was no debris anywhere in the crankcase, none of the other pistons or anything were damaged, so there's no reason to believe any of that stuff is damaged. I'm just replacing these because I'm taking them apart anyway. Removing the crank will require a ton more tearup, which in turn will make this whole thing take even longer.
  #723
Old 02-28-2015, 12:55 PM
good luck with it then ,i hear you everyone wants to be on the road soon
  #724
Old 03-01-2015, 03:22 PM
May 2013 ROTM
So I've got a question about piston rings. I got a set of Sealed Power rings from Summit, and they don't quite look the same as the ones currently on the pistons. As you can see, the new ones sort of have an up and down wave to them, whereas the other ones have kind of an in and out wave. Does it really make a difference, or is it basically two different ways of accomplishing the same thing with the same effectiveness?
  #725
Old 03-01-2015, 04:53 PM
it should go the way it is the strongest, steel edge to ring not bends. are you sure it won't fit. after looking it looks like they work either way, huh.
  #726
Old 03-01-2015, 08:46 PM
May 2013 ROTM
I think it will fit, these are the rings Summit said were for these pistons. I'm just worried about having two pistons being this style and the rest being the other style. Which style have you seen before? I've never done this kind of stuff.
  #727
Old 03-01-2015, 09:01 PM
Don't worry about the difference, different manufacturers can have their own styles like that. Not to mention, those are only the oil scraper rings, not compression rings. Not going to affect engine performance.
  #728
Old 03-18-2015, 03:53 PM
May 2013 ROTM
So I just heard back from the machine shop, they said the valve guides on my heads are totally worn out. A complete valve job and the necessary repair work would cost upward of $900...looks like I need to start looking at another set of heads. SMH.....
  #729
Old 04-09-2015, 02:30 PM
May 2013 ROTM
Dropped off the heads at Livernois to be repaired/rebuilt today. I also dropped off the old rods/pistons to have the new pistons fitted. I should get everything back in a couple weeks.
  #730
Old 04-19-2015, 12:53 AM
Camaro blood runs through's Avatar
Man, you have had some times with this car. I have a 93 Z I am fixing to start playing with as soon as I get my truck. A lot of very good info in here if I run into trouble. Thanks for all the posts
Quick Reply: 1996 Camaro Z28 Project Thread
